Re: Stainless VS Aluminum Prop Question
Well the stainless one is actually borrowed from my brother and it was on a big river boat and is not very good anymore..I do not run anywhere that I should hit anything so aluminum should be fine for my use..Just was curiuos if I buy a aluminum one in the same pitch if I can expect app. the same performance from the aluminum.
no your performance will change a little at least.
you would proably see a large drop in WOT if you went with a 15 pitch aluminum...
I was running 5400 with an aluminum 17 pitch prop, and went to a SS 15 pitch prop, similar design as far as i could tell both 3 blade..
and my WOT rpms went to 6200!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
if it was aluminum I would have guessed the rpms would rise to about 5600-5700.... the SS material accounted for other increase in rpms...less flex
but I hit the prop twcie at less than 1/4 throttle and I bent my prop shaft more than an inch out...and twisted the splines almost a whole tooth!!!!
I sure could have afforded several spare aluminum props and had money left over for the cost of repairing the lower unit!!!
no more SS for me
if you like the shallows and many guys do..especially inshore fishermen....be carefull of the damage a ss prop can do to your motor
good luck
bob
