Stall
TiredoleBoy
Ok the boats is basically together now. But when I place the selector in neutral from drive or reverse it acts like it starts to stall for a moment. I think the lower shift cable is adjusted correctly. It goes into reverse and forward. Could this be the shift interrupter needing tweaking from the upper cable?
Oh and I puled a stupid one today, when testing it for leaks, I forgot to put the damn plug into the boat. It was still trailered though and never left dock.:redface:
Don S
Re: Stall
Would sure help if we knew what you were working on.
TiredoleBoy
Re: Stall
Sorry Sometimes I assume too much.
1988 Barreta Success with a 3.7. Just did a bellows job and lower shift cable to it.
zbnutcase
Re: Stall
The engine WILL sound like its gonna stall coming out of gear back to neutral; thats how the shift interrupt works.
Bt Doctur
Re: Stall
works like that only in the water with a load on the prop, will not do that on muffs unless there is a problem with the shift cable binding.
TiredoleBoy
Re: Stall
Thanks that is what I was wondering, cause it has never done this before. Only since I installed the new cable and adjusted it.
