Re: stalling 15 horse honda
If this is a 15d which I'mm sure it is,you are well over due to remove the gearcase and inspect/replace the water pump unit.Any overheat or low oil pressure situation will cause this engine to stall,restart ,and stall again.A fuel sample may also be well advised as contaminated fuel could cause these symptoms.At 1000 hours a general health check is certainly in order.
