I have a 97 Merc 25 hp outboard... I just bought it from a friend. It's been stored with StaBil for 2 years. I had to rebuild the carb because it wouldn't start.. it was gummed up. I rebuilt the fuel pump too just in case.
It started right up after the rebuilds. I noticed that when it did start, the fuel level in the filter continually dropped. I was told to replace the motor end of the fuel line due to the o-rings possibly going bad. That seemed to help... it only dropped slightly then. It ran good at an idle with the water muff connected.
A trip on the water resulted in a loss of power at higher speeds then it would often stall. Sometimes feathering the throttle helped but sometimes it wouldn't. The fuel tank vent was open fully. I haven't pulled the motor cover yet. Any ideas why it would stall? It starts right back up every time... it's just at higher speeds!
