I have a '96 Johnson 150 Ocean Pro that tends to cough/spit and occasionally die while trolling at around 750-800 rpm's. If I bump the throttle to around 900-1000 rpms, I don't have this problem. The minor difference in rpms results in about 1/2-3/4 mph difference in my trolling speed and is just a bit too fast for the fishing I do. Any ideas on what may cause this problem and how to fix it? The motor has new plugs and the VRO is removed so I'm mixing fuel. However, this problem existed prior to removal of the VRO. I've been mixing OMC T24 in the fuel but it has not helped.
