Stalling, sudden low idle.
ShoalSurvivor
Mercruiser 4.3 warmed up fine.
Dropped it in the bay and she kept stalling in nuetral. Just seemed “cold” at first so I let it warm a little longer. Finally behaved as expected.
Didn’t even get out of the harbor and I noticed my throttle was high, but she was barely moving. Then she stalled again.
Towed to dock. Restarted and ran in nuetral, rev’ed reliably, but idling at 250. She’s not overheating. Temp is at 160°
What could cause sudden low idle? Last time out, no issues.
Is this an adjustment I can make at dock? Or is my weekend adventure toast?
Is this my idle adjustment screw on the fore/port side of carburetor?IMG_3630.jpeg
ShoalSurvivor
Carb. 4bbl
I turned the screw until the tach raised. I thought “that was easy”. (Not sure I did the right thing). I don’t have a separate reach gauge to hook up. Now it’s idling at 850, bit when I put it in gear, it wants to lurch. Makes me think that’s not the idle, but something else. Thanks.
ShoalSurvivor
I turned that screw back down a little. It’s not lurching anymore but still idling at 420rpm.
Is that the right idle adjustment for a 4bbl Weber carb? Is it possible that my tach is just not reading accurately?
harringtondav
That is the idle speed screw. But if it revs in neutral but doesn't idle or deliver power, I suspect a dirty carb or fuel supply problem. Verify a clean fuel filter and that your electric fuel pump is good. Checking the fuel pump can be tricky. It doesn't start until the engine is running and building oil pressure. You can jump the harness leads to the oil pressure switch on the lower rear port side of the engine. The pump should start at key on. Checking pump flow and output involves disconnecting the carb supply line and collecting the gas. I don't have the flow spec, but it should be a steady 3-7 psi flow.
If all good, its time to disassembly and clean your carb. You didn't state your engine year, but you probably have a 3304-9565A6 or -95692, Weber 9600.
The Merc carb kit is 8M0120196, Sierra 18-7749.
Fun Times
Seemingly If your engine was idling and running fine for a long time prior to any other service jobs or adjustments done, then all of a sudden you have both a high and low idle and engine dying situation, then unfortunately chances are to the higher side there’s going to be other issues vs a simple idle RPM adjustment from what does look like the screw in your photo though there are others on that carb that helps with some better idle and running too for fine tuning purposes that’s sometimes a bit better to do with the throttle cable disconnect as the cable could cause issues too should it have gone bad.
Thus far from your descriptions, it sounds more likely you could have something such as say water and or debris in the fuel, an internal carb problem, or even possibly a small amount of water getting into the cylinder's are again just some things of additional things out there to consider thinking about for inspection… < all this if you’ve been keeping up with the tuneup items like spark plugs, distributor, cap, and rotor but they may need re-inspection too.
ShoalSurvivor
Thanks for replying.
2004 4.3 mercruiser repower. I replaced the fuel filter and carb 2 years ago. Looks clean. Only issue I had with fuel was that mfg listed 12-15psi on fuel pump but carb was limited to 7psi. i could not find a lower psi pump, so I added a pressure regulator. Worked perfect after that for 2 years.
I didn’t even have to adjust the idle when I replaced it.
no other drive or throttle work has been done since.
more below.
ShoalSurvivor
some more detail:
ran last night relatively well with the minor adjustment that I made to carb screw.
i had a low throttle issue, but only high issue after I made an adjustment. I turned it back down 1/2 way after that And no more high issue.
the big difference i noticed, and I hope this is relevant info, is that my throttle position is more sensitive. before yesterday, there was some play at nuetral. (Throttle between 11:30 and 12:30, would be in nuetral And no gear engaging). Fwd and rev required moving throttle beyond those positions to engage.
after idle adjustment, it’s 12:00. Period. When I “click“ into nuetral, from either direction, is stays in gear until I put a little extra pressure on the throttle lever, and it engages very quickly. Feels too “tight”
nothing else changed that would suggest a cable adjustment, but I can do that. It only seems to have changed with idle screw adjustment. does that help?
thanks for input.
Lou C
The symptoms you mention suggest internal carb problems like a failing needle valve or bit of dirt holding it open. What do the spark plugs look like (the porcelain insulator of the center electrodes)? White = lean, black =rich that will give clues to point you in the right direction.
When you say you replaced the carb, what did you replace it with? New OEM, or reman? I am very suspicious of reman carbs sold by internet sellers. Often they are not set up right or are combinations of different carbs, none of which is to the specs for your boat.
ShoalSurvivor
Thanks! I replaced the stock carb with an:
Edelbrock 1409 Performer Series Marine 600 CFM Square Bore 4-Barrel Air Valve Secondary Electric Choke New Carburetor
I replaced the fuel pump at that time, too, but struggled to find a compatible pressure. Pumps were over 10psi and the carbs req max 7psi. As mentioned, I added a pressure regulator and dialed it in to 6 or 7 psi.
I will verify output pressure, as that could be a cause, and check the spark plugs. Oddly, now I’m seeing “low pressure” pumps for the 262 that i couldn’t find before.
I appreciate your help and will report back.
harringtondav
I wondered if your pressure regulator may be restricting flow.
3-7 psi electric fuel pumps are common and relatively inexpensive. The challenge is finding one with pipe fittings so you can adapt it to the SS fuel plumbing in your boat.
Below is a Carter pump that I installed on my 4.3LX. With the correct brass flare adapters it was a perfect fit replacement with the Merc expensive OEM pump. I had to splice into the original pump wires.
Lou C
This is carb was bought new but now it's 2 years old correct ? Have you contacted Edelbrock tech support? The only thing I have ever heard of with these carbs is that one of the floats can be too close to the side of the float bowl and cause the float to stick. One thing you could do is remove the carb, drain out all the gas, let it dry and see if you can using an appropriate sized hose, blow through the fuel inlet with the carb upside down, that's an easy test to make sure the needle valve holds.
Scott06
I would verify your fuel pressure is ok and the regulator is still working ok. usually there is a gauge port on the regulator. Would also look down the bores to see if fuel is dripping off the boosters at idle. If present this would mean the fuel bowl is overflowing due to high fuel pressure or defective needle and seat / float
the idle mix screw are on front of the carb and can change the amount of fuel going in at idle. Might try opening and closing them one at a time to see if it affects idle quality. If changing them has no effect you likely have clogged idle passages and carb needs to be cleaned and rebuilt.
what do the spark plugs look like and contents of fuel filter
ShoalSurvivor
I would verify your fuel pressure is ok and the regulator is still working ok. what do the spark plugs look like and contents of fuel filter
Updates:
1) fuel pressure is still dead on at 6psi.
2) Plugs look clean:
3) No fuel leaking in carb.
4) fuel is clean
5) Ran her all weekend with no further issues.
Before taking her off the water, I played with the carb idle adjustment.
I found that at lower RPM (400 rpm, based on dash gauge) she did not stall, AND the shifting was very smooth, with anticipated neutral zone on throttle arm.
When I increased it to 800rpm, it was throttle was jumpy and tight (hard to get it to disengage to neutral, and immediately shifted fwd & rev with little to no play.
I set it to ~600 rpm (spec is 650rpm) , and it seemed to run perfectly. I will bring an external tach and fine tune it next time I get on the water. I will also verify throttle cable adjustment, but as mentioned, it continues to perform well at target idle speed.
This leaves me with 2 questions:
1) is the throttle engagement described expected to vary based on idle speed? I would have expected a shift cable adjustment to affect the "engagement zone", not idle speed. Would be helpful to understand what to expect here.
2) what else could have caused idle speed to drop (and need a tweak), which seemed to cause the initial stalling? Is idle speed something that typically holds unless other work is done (I had performed no other work for the last 12 outings).
Thanks, again, for all the input!
Scott06
Updates:
4) fuel is clean
Plugs look a little rich but definitely in the normal range.
did you adjust the throttle cable or idle speed screw or both?the throttle cable should be long enough that when you set the idle speed screw to what rpm you want with The throttle cable off the carb Throttle lever. Once idle is set turn the adjustment on throttle cable so it is long enough to push it firmly against the stop.
Not sure how much you turned the idle speed up (turns on screw) but if it idles ok at indicated 400 rpm your tach is probably. A tad low. You need to be Able to get it fully in gear and still have it at idle So it doesn’t jump when you put it in gear
only thing I can think is the screw was backing off While using it. Id mark it and see if it backs off over time. I had a should screw fall off my mercarb years back. It held on a cam that the idle speed screw sat against so when it fell off the throttle plates completely closed at idle, so it would die. Luckily the screw was still on the manifold …
ShoalSurvivor
I didn't remove the throttle cable when adjusting the idle. THAT explains a lot, and jives with my expectation. also, having it at idle, while in gear, is exactly what I had, and now have again. At higher rpm idle without removing the cable created the "lurching" - dangerous, and nerve-wracking in close quarters, and I'm sure not good for the drive.
It sorted out ok for "an on the water" - end of season - fix. I will be servicing the drive soon, replacing bellows and trim sensors this time around, and will readjust the cable when finished, then follow procedures for the idle when I get back on the water.
thanks for taking time to respond!
Scott06
If you don’t have them get the factory manuals for both engine and drive. Has great info and procedures for stuff like doing the bellows. i bought used ones off ebay
