Stallling 225 Mercury Outboard
circlehook
I have a 225 HP mercury offshore outboard, and it idles good up to 1,500 RPM, and if you can get her up to 2,500 RPM she runs fine all the way up to 4,800 RPM, but between 1,500 and 2,500 she keeps stalling and really no power, every thing from the filler caps right to the primer ball is brand new even a racor water/filter she ran 25 miles off shore with no problem, but in the harbor no wake zone she will stall, any one ever have this problem thanks bob
PS the motor is a 1996 with carburetors, 2 stroke injection
blue_matt1
Re: Stallling 225 Mercury Outboard
Ive posted similar got same sort of problem feels elecrtrical this is what ive psted wit no replies
Dont know if anyone can help have an old 200 merc 93/94 ish has an annoying flat spot at approx 2000-2750rpm anymore its clear any less its clear when was last out it was the most slightest of change of engine speed it was either slightly flat or fine as if turn a switch on or off have had carbs cleaned overhauled new fuel filter plugs new stator and flywheel had a look in tank looks fine and is venting ok its really bugging me if you get my drift last year plugs seeemed to fix it for a few hours thats why i went for stator heard its a sign of stator failing just had a look at connections on wires going onto some boxes from coils are these switch boxes?? going to clean up and try problem is only there under load so have to put in water to know if cured oh and ive tried giving choke also when it does it no difference basicly if driven flat out its fine and keep over 3000 but if going through harbour its a bit of a pain anyone have any ideas looked on various problem sites and it seems to be quite common oh one other thing every now and then rev counter doesnt work may be related may not this has only happened at home though never whilst out
LA PILOT
I have the same problem on a 1996 225 offshore--hard to get above 1500rpm. Once over 2500 -3000rpm runs great. Seems to be very low on power. Sure would like ideas as to where to look as seems others have the same problem.
