jonny rotten
- Joined
- Jan 8, 2012
- 380
Finally unwinterizing the boat..The boat stalls when going into reverse but goes into forward fine.If I get on it shifting into reverse it will stay running.This is with muffs on in the driveway.I put the outdrive on in forward gear.It worked perfect last fall..Did I not do something correct? Would this have anything to do with the barrel needing adjustment..I read it should never stall Going INTO gear so not sure what the barrel adjustment would do
