Knight1396
- Joined
- Jul 23, 2009
- 15
Hi everyone!
I have Twin 7.4 thunderbolt bravo 1 engines in my Regal 320.
My Port side engine turns over and fires right up, my Starboard engine
seems to click then if I run my starboard engine about 20 mins it will
slowly start to turn over.. til eventually enough to fire it up.
I checked the starter and have 12 volts there until I turn the key it drops.
I noticed that there are 3 ground wires coming from my battery charger..that were at some point taped together
to the ground wire off the charger.. these were not tightly taped or joined... so I connected them all solid..
then.. smoke from everywhere on the boat.. it started with the battery to my generator terminals, then to the Gen,
and then in the cabin behind the circuit board, I smelled the burning smell of electric, opened it up and the zinc saver was really hot and the grease pac had begun to melt..
This was happening on and off shore power..
Until this time, the boat has run good, no problems and just at once it started acting up ..
I am thinking time to pull it out of the water.. but any advice will be greatly appreciated!
