Mainecrafter
- Joined
- Jun 21, 2015
- 15
Alrighty . . . so a little backstory here. A buddy of mine and I were doing some island carpentry work for a service organization here in Maine and this Starcraft was donated to the org. They didn't have time to fix it or use for it so we traded some labor and a little $$ to take it off of their hands and it essentially functioned as our pickup truck for several years. About 4 or 5 years ago, we were moving it from his dad's driveway to my house when the axel on the trailer broke and we convinced a AAA truck to haul the whole thing to my yard where it has sat (with canvas cover in place) since. I had just become a parent and really hadn't had spare time or cause to mess with the boat. Fast-forward to about a month ago when a friend tagged me and a couple other folks about going in on a boat together and we're now taking a renewed look at the old, beloved Holiday as a co-owned boat . . . we're all semi handy but also might know just enough to be dangerous so we're looking for help and guidance in this process. Any sage advice is GREATLY appreciated.
We've seen some admirable Starcraft renovations in this forum. But we're all pretty busy and can't justify extensive expense for a museum-quality restoration, at least not at this point. What we're looking for is to get the boat safe and water worthy for some summer excursions. I think we're all in the place to spend smart money to do things right but aren't trying to make a showboat out of her. That's the sweet spot we're aiming for. Here's a list of items we're looking to do this summer with attendant questions:
TRAILER:
Found an adequate replacement and have already done the slightly tricky juggle of getting it off of the broken trailer and onto the new one.
DECK:
Totally rotted and needs replacing. We tore it out yesterday (saving any pieces that were intact for patterns) along with 4 contractor bags of old carpet, watterlogged foam and beads and mice nests.
• Anything we should do to the inside of the shell while it is exposed?
• Best affordable foam replacement? Can blue/pink rigid be used?
• Best deck replacement? Is it worth using marine-grade ply or is ACX a workable alternative (and if so should it be treated and with what)?
TRANSOM:
It's a bit punky on one side where water had pooled but it seems largely intact where the motor mounts. I think we will replace next year and just try treating the soft areas with some penetrating epoxy to get through this season, largely to avoid removing the outboard and messing with all the cabling. Tell me if this is a bad idea.
HULL:
Boat was frequently left in salt water and the aluminum shows some moderate pitting (see images). Best way to address this? Light sanding? Best affordable paint solution? Do seams need to be addressed before painting and with what? Boat will still be periodically used in salt water but will be trailered and washed off religiously.
OUTBOARD:
It's an early 80's Johnson 70hp 2-stroke. The trim unit was trashed on it when we got the boat and we would just manually haul it up and lock it upright when we were using it. Sitting for 5 years, the hydraulic (which had no fluid) is now rusted into immobility BUT my auto mechanic had a functioning replacement kicking around that he's selling us for cheap so we plan on swapping it out and having the motor tuned up (although it started right up when we first tried it and seems to run fine).
Beyond this, I think we're not going to take on much more this year but we're already feeling the allure of putting future work into the boat to make it shine. I'm trying to cull some of these answers from the forum but there's so much to read that any concentrated advice is really appreciated. Hope to see you on the water soon . . .
TRAILER:
DECK:
TRANSOM:
HULL:
OUTBOARD:
