starcraft boat info ?
Chief Don
I am looking for some info on a Starcraft Chieftain Mk IV, 22'. can anyone help. Thanks and merry Christmas. Don.
D
DJ
Guest
Re: starcraft boat info ?
Great boat. Very light for its size.
It is a close relative to the Holiday, Islander and Super Sport. They all used the same hull. The Cheiftain and Islander were both cuddies with the Cheiftain being the larger of the two.
Chief Don
Thank you, Do you know where I can find out what type of engine this boat had. I am looking to buy it from a friend who has no info on the boat. Its in nice shape but missing engine and out drive. Thanks again. Don.
Ayuh,.......
What Year is the hull,..??....
Starcrafts came with Mercruisers,+ a few OMCs,......
Some pictures would Help in identifying what the outdrive was.....
1970 Chieftain V
Does it look anything like this?
Jason
D
DJ
Guest
If it had an OMC drive, the hole in the transom will be quite large and almost square, with rounded corners.
If it was a MerCruiser, the hole looks kind of like a key hole.
For you, I hope it had the latter.
I had a 1979, 25 ft Chietain with a four cyl mercruiser, it did all right for me, and had plenty of power for that size.
Chief Don
Thanks, I was wondering about the power level of a 4 cyl. Just going to be touring Lake Powell AZ. and some family fishing.
Chief Don
thanks,I fond out it had a mercriuser. now to find one......CHEAP!
Chief Don
Looks similar, same idea on the cabin/conning station, a little more sleek hull design.
D
DJ
Guest
Look at item # 180196853157 on ebay. It's a complete drop in 3.0L 4 cyl. (135 HP) MerCruiser. Pretty much a direct drop in unit for your boat. The old 4 cyl's were 120 HP, at the prop, at best. The newer ones are 135.
There are usually other examples.
silvrfoxm
Check post "Starcraft popping paint below water line" & "Starcraft leaky glove box"
ricwing
I had a starcraft mariner 18,1989, the bottom started having little pin holes appearing which were caused by electrolisis,had to scrap it. start out looking like a little bump that would pop.
