DANZIG
- Joined
- Aug 17, 2009
- 117
I have a kissing cousin to your SC Cuddies, a Sylvan/Smokercraft 1982 Offshore(?) outboard.
It's just about transom time! I have gotten as far as to cut to width a couple 3/4 MDO boards and now have several questions.
1. Required bolt holes,, Drill before laminating the boards together?
I am thinking that will make it easier to oversize and epoxy fill them before redrilling back to size.
2. Laminating the boards together,,, Will I need a filler of cloth or flour to get good adhesion?
3. Stiffening the transom,,, I have only one knee and can't go thicker with the wood on account of the transom "tray", perhaps aluminum angle (at an angle) from the top of Gunnel(?) transom attach point down to the transom "tray"?
Useless? Overkill? Good idea?
4. The splashwell "U", The original "cap" for this is long gone, Keeping the bend in mind, What would be a suitable replacement?
5. The splashwell aluminum "box" to transom,,, I am thinking an aluminum sheet on the transom wood with butyl rubber tape to make the seal. Yes, no??
And, on a side note, Can laminating/coating epoxy be used as a substitute for "Gluvit" to seal seams and rivets?
Thank you kindly!
Thank you kindly!
