natemeins
- Joined
- Oct 20, 2013
- 73
Hey fellas.
My buddy has a Bayliner Capri with a Johnson 110. Good pulling boat, but really has a hard time with plowing out of the hole, and when it's on plane it has little to no trim before it starts porpoising like crazy. Also, his fuel economy is pretty terrible. After doing a bit of research we had a look at his cav plate at cruise and sure enough it buried. Luckily for him, his motor mount allows it to be moved up or down with a series of holes where the mount bolts go through. As of yesterday his plan was to try to move the motor up a hole or two. On my old 14' flat bottom with a Johnson 30, the cav plate skimmed across the top of the water, just perfect as it should at cruise.
So I had my '71 Sprint with a '71 'Rude Lark 50 out yesterday, and for S & G's I had a look at my cav plate at cruise. Interestingly, it was buried. Every now and then I could see it, but for all intents and purposes, it was under water. This sort of makes sense as to how I can pin the motor tilt to the next to highest tilt angle and still jump out of the water and not cavitate. Another hint was that a few weeks ago I tried out a "standard" size prop for my motor, a 13-1/4" x 17. It was a dog! Terrible performance, motor couldn't make good revs. It currently runs a 13-3/4" x 15, engine sounds like it's screaming along at WOT (no idea of revs, no tach...yet). GPS shows 27-28 mph with just me and some gear in the boat.
I took a few measurements, and with the motor tilt pin set in the middle hole (of 5), the cav plate is nearly dead nuts level with the bottom of the keel, and the lower unit leading edge is approx. 7" from the back of the transom. My research into motor heights tells me that for every 12" of offset of the motor, the cav plate should be moved up 1".
Those of you with tinny 'crafts, where do you expect and/or have your motor heights at? With this type boat should I still expect to have the cav plate skimming the top of the water? After seeing how easy it was to move my buddy's motor up, I went to look and do the same for mine. Unfortunately, my bolt holes are not adjustable. What sort of methods could I use to move the cav plate height up, say 1/2"? I thought of placing a block of wood between the transom and saddle of the mount, but of course new bolt holes would have to be drilled, and that's assuming I wouldn't wind up "snowmanning" the holes. I plan to rebuild the transom this winter, so if I can/should move it up, I can always make the transom height a little bit taller. Is there a way to experiment with height prior to drilling into the transom?
Would love to know what you guys think.
