Starcraft Islander
UpstNYer
Looking for opinions on the Islander. Anyone have any experience with them or know of their reputation? Application would be primarily fishing on Lake Ontario and overnighters.<br /><br />Are there any model years or options to stay away from or look for? Anyone with a 19' that wishes he had gotten the 21' (or vice versa)? Any high upkeep items on them? Do they handle rough water well? Any comments on their engine packages?<br /><br />Saw a nice looking one the other day with lots of weeds growing around it.....hmmmm.<br />Bob
D
DJ
Guest
Re: Starcraft Islander
UpstNYer,<br /><br />The Islander is one of the finest purpose built boats out there. I have spent many an hour on lakes Michigan, Superior and Huron on a 21' Islander.<br /><br />They are very light for their size so the wind tends to blow them around a bit. They sit high in the water and the small cabin tends to act like a small sail, especially in a wind from the stern.<br /><br />With that said, they ride quite well, are dry and tough. Plenty of freeboard (great for kids or non swimmers) can handle heavy loads and get away with far less power than their fiberglass counterparts. They are also easier to tow than glass boats of similar size.<br /><br />If I had the storage room and the need, I'd have one in a heartbeat.<br /><br />The boat gives the operator and passengers a great feeling of security.<br /><br />Make sure you power it to about 75% plus it's rated capacity. Just because you have the ponies, doesn't mean you have to use them. Resale will be very good.
mellowyellow
ditto DJ... lookin for one myself 4 lk. ontario.<br />great set up IMO.
Lark40
My islander has two distinct benefits for it's size. One is that it handles waves very well. The second is that it is a great trailer boat due to it's light weight.<br /><br />Mine does have leaking rivets, as do others I've heard of. No problem for trailer boat with a bilge pump.<br /><br />All things considered, I would highly recommend the 22' Islander.
butch290
I like mine, 26' with a 350 omc, the drive has it's weekness but I have observed that having less power may help it.<br /><br />Rough water: It my not be the fastest but I feel safe in 6 & 7 footers.<br /><br />Watch for water soaked foam under the floor.<br /><br />Trailer and boat weight is 6200 lb<br /><br />I agree with all above.
I have a 1974 221 Islander.....<br />I also agree with what's said above....<br />The Biggest Reason I'm going to a 25' Glass boat is the Rough Water Handling....<br />Being a reasonably flat bottom tin boat, the Islander rides pretty rough in Serious Chop,+ is a Bear to keep in a straight line going Into the Wind, at Trolling Speeds....<br />Even though mine is about 30 years old, the Newer 1s are the Same Hull as mine,except for the taller cabin windows, it's the Same Boat.....
BLU LUNCH
I spent many weekend fishing out of Pulaski NY on my buddies 1988 26'footer. The boat trailers nice we used to trailer from Westfield Mass to upstate NY thru the Berkshires with a 1/2 ton Ford pick-up. The boat is light for the size. On the lake even in rough water the boat handles like a charm, I don't remember the size of the motor but I do remember him saying that the bore and stroke as the same as a 460 Ford it was a 4 banger. It was good on gas and we would idle trolling for 12-14 hours a day in 3 years we never ever had a single problem..........
Throbbin Rods
I just bought my second Islander 191V, fish Lake O, Winnipesaukee, Champlain and the Connecticut lakes. Love it. With a 115 Merc it jumps on plane fairly well and is a champ in rough water
UpstNYer
Thanks for all the input guys. Looks like this boat has stood the test of time and is well suited to my intended use/means. Putting it in the 'definitely consider' column on the list of future purchases.<br /><br />Terrific the way this forum brings decades of experience & expertise within reach of just a few keystrokes.<br />Bob
