I finally have the thing stripped down to just aluminum. I discovered two holes in the floor one is still open and the other was filled with a screw and then had some kind of sealant applied. I suppose I can just have all twenty some holes in the hull simply welded or is there a better solution. I have lots of questions
1. There was white styrofoam under the old floor should I do that again? what a mess.
2. Should I seal the plywood floor on both sides before installing? I'm inclined to think not because I'd rather have it be able to breathe and I think carpet glue won't stick well to sealer.
3. I see some of the rivets in the bottom of the boat were sealed with something clear that is now failing. some of these rivets are circled with a red marker as if to indicate possible leaking. Should i strip out the old sealant and apply something else? what would that be?
4. Should I simply make this a row boat and go buy a nice boat to fish out of?
Photos of completely gutted boat
http://s659.photobucket.com/albums/uu316/jambla/Completely Gutted/
Partially Gutted
http://s659.photobucket.com/albums/uu316/jambla/Demolition/
The mess I started with
http://s659.photobucket.com/albums/uu316/jambla/Jet Star 15 Before/
Partially Gutted
