Hi all! I own an '87 Starcraft Medalist 19 ftr powered by a 3.0 OMC Cobra. The transom is shot so I've decided to go ahead & do the repair. I'm not sure how to proceed so I'll run this past the experts here. The transom is approx. 72" wide. I have most of the old wood removed & here's what i found. Starcraft built the transom using 2 layers of 3/4" plywood laminated together which spans approx 4 ft. of the transom. On each side of this span they finished the transom using 1 layer of 3/4" ply, about a foot wide. My plan is to build the new transom using 3/4" ply laninated together & glassed back onto the hull for the 4 foot section, then finish the transom by butting the 2 one foot pieces back onto the hull using pb thickened with Cabosil to finished off the transom. My question is, is this a good idea? Will doing it this way give the transom enough structure & strength so to speak? I'm not sure if I can maneuver a 72" span of new plywood into place as room is tight in the engine compartment. I've already torn out about a foot of solid flooring & stringers on each side so i could remove all the rot & i hate to rip out more good wood. What do you guys think & thanks for your help!
