I recently purchased this boat used. I did something quite stupid.
While looking for a reason something electrical wasn't working, I went under the console and found two fuse holders. I opened each up and took ok the two small (approx 1 inch) glass fuses that were in them.
I thought I put them back in where they went but am now second guessing myself
One fuse I have traced back to the Guest battery switch which I think was a BUSS 3A 250Volt 312. There are two wires(yellow and red) running from under the console back to this switch. This fuse has a very thin wire element in the glass. Fuse is on the RED wire
The second fuse was in the holder on a wire that was attached to the back of the gas gauge. This one was a BUSS AGC5 - 32V and is a very wide/flat wire in the glass. This fuse was on a PINK wire(maybe it was red and faded?) I really don't know what this one is for because if I remove the fuse, everything seems to still work (gauge, light as well as other accessories)
I swear this is how they came out, but my memory isn't the greatest and for some reason,
it just doesn't make sense to me that the thick fuse would be in the wire going to the gas gauge and the thin one is going to the battery switch.
Does anyone happen to have knowledge of or have an SS160 and know what fuse would be in the wire running from the gas gauge? Or, what size fuse should be in the wire running from the console back to the Guest batter switch?
I'm paranoid I have these in the wrong position now
Any advice/help is appreciated.
Thx in advance
Thx in advance
