Prairie Bouy
- Joined
- Jul 31, 2006
- 19
The motor was running fine, or so it seemed. I discovered an air leak in my fuel hose. It caught up to me late last season and left me at the ramp and wouldn't start. Needless to say I didn't get the engine fogged before storage.
I've found the air leak, but the engine would not start. I read the secret file and found that the engine will fire by injecting fuel/oil mix into the cylinders. I figured that everything just may be flooded with oil. Seems thats what it was as oil poured from the carb cover as I loosened it off. I then tried injecting fuel/oil into the carbs. Engine fired. But it wouldn't run by regular start sequence.
I pretty sure I have some cleaning to do, and possibly some replacing. Where and what should be done?
Is it safe to run the engine by the red levered primer valve on the solenoid? Found it would run by this but I tried it for a short period of time. The engine would quit when put back.
I also discovered that water is leaking from around one of the spark plug holes. I am hoping this is just a water jacket gasket. There was no water in that cylinder or any of the others.
I do have a service manual and have a bit of mechanical savvy. Perhaps just enough to be dangerous.
So, am I in a lot of trouble?
Very best,
Al
Very best,
Al
