Started to get off trailer, now won't start
HeavyDinKC
Hoping for some beginning guidance here please.
Boat started to get off the trailer today...idled and sounded good over to the courtesy doc. Shut it off to go park truck. After getting back, boat will not start. Last time we had it out was about 2 weeks ago. Ran great. Been running great all season.
Thought it might be the safety switch, but I've made that mistake before, and when I've done that, it starts for like 2-3 seconds and shuts off.
Short video of attempting to start in the driveway with muffs on.
Boat/Engine details:
2011 Tahoe Q5
4.3L Mercruiser TKS SN: 1A625559
Please let me know what additional info you need from me. I have yet to do any troubleshooting. I'm just hoping you can help point me in the right direction, and if it's an easy to moderate difficulty fix, I will attempt. Otherwise it's off to the shop.
Need to find out what your not getting, fuel or spark.
Move the throttle forward and see if you see gas squirt down the throat of the carb
Check for 12V on the positive side of the coil when the key is turned ON
scottn83
All dodge gave great advice I had the same problem with mine. The only thing I would add is when you check for fuel in your carb just because there is fuel there doesn't mean there is enough. I was getting fuel in the carb but not enough. Change the fuel filter and bam starts ever time
CaptainMak
First of all, when you turn the key to the IGNITION ON position, let the beeps finish chirping, and the fuel pump cycle though. You're starting it way too early and the pump is probably not having enough time to build up the pressure before starting.
Secondly, that looks like Throttle Body Injection ? If it is, spray some starting fluid into the flame arrestor and try cranking. If it starts up and dies in a few seconds, your problem is fuel. If not, your problem is spark. Let us know.
Swimforshore
I agree with mak a little starting fluid or even brake cleaner and in a pinch a spray bottle of gas sprayed down the throttle body while cranking will help isolate it to fuel or ignition. If it's ignition look for arc marks especially around ignition cool and inside of distributor cap
glennj3
What ever you do, do not spray any gasoline anyplace! The gas fumes are extremely explosive! Starting fluid, OK.
If I had tools at this point I would probably pull the fuel line at the carb and see if it has pressure, and check the fuel filter.
HeavyDinKC
Thanks guys...I'll try to get out later this afternoon and use your advice and report back.
bruceb58
He listed in his original thread that he has TKS so he has a carb.
Do not use starting fluid. Good way to damage your engine.
HeavyDinKC
Ok, I know it's been almost 3 weeks since I started this thread, and you can beat me with a wet noodle after I ask for your assistance.
Since my original post, about a week after my last post, went out, and it started right up! It ran multiple times with no issues since then, I believe we've been out 4 times.
But then the same thing occurred this weekend as my original post. Got out Sunday morning to clean and I've had the habit the last three weeks of starting it in the drive way and warming it up while the kids are getting ready. 35 minute drive to the lake. Then it wouldn't start. So I busted out your guys recommendations. Below are what I've able to perform. Hopefully you can help point me where to go next.
Move the throttle forward and see if you see gas squirt down the throat of the carb Check for 12V on the positive side of the coil when the key is turned ON
I'm getting 12V on the coil. Had a hard time seeing if gas was in the carb as I didn't have a helper today.
I changed my fuel filter in July 2016. Took it off today. All gas that I poured out was nice and clean.
Finish chirping, ok. I found what I think is a bit of a pattern here. Let me know if I'm just way off base. When I let the beep run, it just keeps beeping. The longest I let it go before I tried again was 3 minutes. BUT, what I think I found, may be the fuel pump. When the beep came on, and I lean into the engine compartment, I could NOT hear the fuel pump. But when there was no beep, the fuel pump was running. And then it would run for 10 or 20 or so, and then then the beep would start up again.
DOn't understand this statement, the motor ran for 10 to 20 seconds and then died or something else?
When the motor starts cranking the fuel pump should start running. Might not hear the pump over the beeper. If cranked long enough (few seconds) oil pressure starts to build up and turns the beeper of, this allows to secondary full pump circuit to start.
So now I think you have an electrical issue. The carb should have some fuel in it, and that's all it needs to fire. To check for fuel in the carb, take a paper towel an push in down inside the throat of the carb. Now pump the throttle and pull the towel out. There should be gas on the towel
HeavyDinKC
AllDodge: Had enough time after lunch to try the paper towel. Yes, there is fuel in the carb.
On a different note, I believe the battery is running low with all this cranking and no running. I'll pull it out tonight and have it tested, just in case.
Any other thoughts on where I should be looking?
Have fuel, and probably no spark. Don't have your manual but you should have the TB-V ignition I'm thinking. The first thing is disconnect your tachometer (the gray wire). Tachs can short out and if that happens then no spark.
If it won't start, run through this troubleshooting guide to determine what isn't working
HeavyDinKC
Thank you... Battery was bad, replaced, but still no start. Pulled the tach wire, no luck. Rain starting here, I'll have to pick it up later or tomorrow.
HeavyDinKC
Ok, here's what I've done so far. Have to run up to get a spark gap tester before moving on. Have a few questions to be sure I'm interpreting everything correctly.
1. Bottom of distributor, 3 wires coming off, White/Red and White/Green to what I believe is the ignition module.
https://www.amazon.com/clouddrive/sha...hare_link_copy
2. Ignition module. The White/Red and White/Green go into the top plug harness
3. Plug harness into the ignition module. To do the last step, it seems that I will have to pull the White/Green wire from the harness and tap it against a ground. Is there another way around this?
My results so far:
No change when remove the tach.
Getting 12v on the positive side of the coil.
Getting 12v on from the corresponding pin to the White/Red wire from the ignition module.
Apparently I'm doing something wrong when trying to upload pics...I keep getting an error, hence the links above.
OK, I see your issue. This is why when the sensor is replaced they provide terminals with bullet connectors, yours currently does not have them. TBV sensor.jpg
When a new sensor is replaced, the wires coming from the sensor in the distributer are removed. The ring terminals are put together with the short screws and nuts, taped up, and then the bullet connectors are used.
So here is what you do. Remove the coil wire from distributer and place in spark gap tester, or have it held close to a good ground. Next remove distributer cap and lay to the side with all wires attached. Remove the Wht/Red wire from sensor and test per the trouble shooting guide.
If 12V are found, then reconnect the wire. Now remove the Wht/Grn wire from sensor and do not let it touch anything. Take a jumper wire and attach to were the Wht/Grn wire was removed, then follow troubleshooting guide.
HeavyDinKC
Ok, wow, I'm very slow to pick up and a bone head.
The bullet connectors were hidden below a coolent pipe and I thought it was solid wires... Moving on as previously instructed. Sorry
