I'm running a 1997 4.3 GL 6 cylinder (GLPLKD) with an SX-C outdrive in Lake Erie. In the past I've had one of the local shops winterize for me, but this year I decided to do it myself. I'm working from the SELOC manual, stuff I've read year, and a few "how to" clips online.
So today I did the fuel stabilization / engine fogging / seawater cooling system. A couple things I'm wanted to get some expert help with.
1) With the fogging, I expected to hear the engine lug / smoke / stall out as I emptied the fogging oil into the carb. However it didn't even hiccup. I even made sure to get the spray straw through the little pin holes in the intake plate. Finally I just closed the choke plate with my hand and it stalled. Should I be concerned?
2) I used the "disconnect all hoses, drain & pour antifeeze" method on the cooling system, rather than the bucket, hose and muffs method. Now, the SELOC says to actually remove the thermostat and pour the antifreeze directly into the block, but I didn't do that - I poured it down the large tube that runs from the thermostat to the water pump. I also poured antifreeze into "long supply hose" to the sea-water pump and the hoses that go the exhaust elbows (That was after I opening two engine block drain plugs and the rubber drain caps on the exhaust elbows.) In total it took just less than 3 gallons of antifreeze. Seems like it probably was about the same amount as the water that I drained out, but I'm just concerned that pouring it through the hose like that it might not have gotten into the block otherwise why would the shop manual have me go through the extra trouble of removing the thermostat.... Should I be concerned?
3) Step 16 in the SELOC says for SX drives to tilt it up, and remove the water drain plug on the port side of the pivot housing where the upper housing attaches to the bell housing. The only "plug" I could see was the same as this one: Drain plug on 98 Volvo Penta 4.3 SX Cobra, and sure enough when I pulled the plug, other than some crud, the inside looked cast solid... So is no "water drain plug" on the 1997 outdrives / the SELOC is just talking about draining the older OMC outdrives... ?
4) This boat saw about 10 hours total in the water this season. I had the lower unit gear oil changed at the end of last season, so my thinking is it shouldn't need to be done again, given how little use it got. Does that seem like a safe assumption?
Thanks in advance for the help!
