orlandoclippertim
- Joined
- Jun 2, 2011
- 106
tried a first start of a rde-17 Johnson. new ign. water hose on reverse outlet- and in plastic barrel.
Used syringe to shoot a bit of fuel past throttle plate. Pulled rope-- blam-blam-pfft git a few kicks.
Then I tried the same thing again with starter. on about the 3-rd go with the starter --- the Bendix gear stuck
in the "up" position. Locked tight. took flywheel off and then took starter and bracket off. Pulled core out of starter.
Now I see the problem. There is a steel cap just under the end nut. When the gear spirals up-- a small return spring
is compressed. that spring - as it compresses- goes up inside that end cap. there is a passage cut into the underside of the cap so the spring has a place to go as the gear bottoms out against the lower edge of the cap. The problem is-- this
cap seems to be bent a little so the gap that the spring goes up into is too big on one side and not big enough on the other.
I think when the gear climbed the spiral the spring got pinched and prevented the gear from dropping back down as it should have after the ring gear overspeeded it. If I can remove the end nut-- I can replace that cap. ( If the shaft isn't bent there-)
The question is--- I have the starter rotor out-- what part of the rotor assy. do I grab so I can get the nut off the tip of the shaft? Looks like right handed (normal) threads there. Is the laminated core area strong enough to hold with something
????? Like a wood jawed vice or a chain wrench with padding ?
Also the insides of the starter are greasy and dirty. I would guess something like a spray can of CRC motor cleaner would be safe-- followed by compressed air ?
Anyone done this ?
Tim
Anyone done this ?
Tim
