Starter Bolt Size
whywhyzee
I am finishing up a rebuild of a 1993 90 HP Johnson. I am missing a bolt for the starter which attaches at the top corner of the intake manifold. PicsPXL_20220812_204052530.jpgPXL_20220812_204221841.jpg attached. It seems to be a different size and/or pitch than the other 2 bolts. Does anyone know the specs for this bolt. I've searched diagrams online and can't seem to find it. Thanks!
saltchuckmatt
I am finishing up a rebuild of a 1993 90 HP Johnson. I am missing a bolt for the starter which attaches at the top corner of the intake manifold. PicsView attachment 367770View attachment 367771 attached. It seems to be a different size and/or pitch than the other 2 bolts. Does anyone know the specs for this bolt. I've searched diagrams online and can't seem to find it. Thanks!
All three should be the same. 1/2 bolts, not sure of the thread though. Looking at your motor with all the Allen heads and stuff maybe someone had to tap that out.
Crosbyman
try slowly turning a stick of wax in the hole to copy the thread and diam..... unscrew then measure dia & thread count
or used various taps till one screws in properly
whywhyzee
I assumed the Allen heads were OE.
I ended up removing the intake manifold for a better look. Turns out a bit of gasket was interfering with the bolt. Cleaned the threads and gasket and no more problem!
