Erie Canal Boater
- Joined
- Mar 19, 2008
- 13
I posted earlier that my starter was working when it wanted too and everytime I loosened up the starter and wiggled it would wor. I took starter out took to Napa they did a test said starter was fine not drawing any more volts&s then it should. I have cleaned all coonections and don a test on the positive wires.
Whats the best way to test the -neg part of the circuit?
When I took starter out there was oil around where it mounts, I'm assuming this might make the connection bad. I will clean area up an try again. Should I put a new ground cable on?
Any advice or things I should be lookin at appreciated.
