Good day!<br /><br />When I try to start my starboard engine, the starter just does a single "click" sound. <br /><br />When I pluged in battery changer and switched positioned a switch on charger to "50A", it "clicked" again and did not turn the engine. <br /><br />I took booster cables from the port engine to the starboard and it started right up.<br /><br />I have 2 batteries connected in parallel on each side. Voltage reading on the starboard side (one that does not start) reads 12.56V .<br /><br />Is it possible that one battery is dead and is draining crancking power of the second battery while starting?<br /><br />How could I check without load meter? <br /><br />Thank you
