Starter clutch gear?
Kenjanr1
I have a 1984 Sears Craftsman 15 hp motor, Model #217 - 586353. The starter clutch gear as I call it is mounted on the side.
The gear broke and I cannot find one anywhere. I have called sears parts direct and they tell me the part is no longer available. I have searched online and cannot find the part. Any suggestions? The part number is 590435A. It's the gear that engages the flywheel to start the motor
M
mrcrabs
Guest
Re: Starter clutch gear?
Edit::D
I'm glad you got what you needed, good luck with your motor and boat and if I can be of help just give me a shout
jim j geezer
There might be another option, but it's probably a long shot. If there's a high school/community college in your area that has a metal-working machine shop class, you might be able to get that gear fabricated from metal on the cheap.
