Re: Starter current
Im guessing but amp draw on yhay size motor would be 175 amps give or take 25 dependind on condition and age of starter. now how are you going to measure amp draw I know how to do it on a car in service garage with a vat. but a boat seems a little harder to do that on. so as 99yam40 said lets look for voltage drop, voltage will drop at a poor conection, you can't always tell by looking. i have seen cables that look fine, that showed voltage drop, and once i cut cable open i found cause, corosion. you could try a good set of jumper cables and buy pass switches and relays. this will tell you if your starter is the problem or not. and if starter test ok then you still have to fine the problem. a voltmeter can get you your answers
