Starter/flywheel alignment
DMT78
Newbie question I guess: I was running(connected to flusher) my 1999 Yamaha 115hp outboard, when I heard a loud PING sound. Motor kept running but when I tried to start the motor again it wouldn't turn over and sounded like starter wouldn't engage the flywheel properly. I looked at the pinion gear on the starter and it is not aligned with the flywheel, shouldn't it be? <br /><br />Any help is greatly appreciated.
DMT78
Re: Starter/flywheel alignment
What should I do to correct this problem?
Ray Neudecker
Be sure the starter is bolted securely to the block and nothing is broken there. Then check to be sure the flywheel is not moving sideways due to a bad main bearing. lubricate the shaft the starter gear goes up and down on to be sure it moves freely.
