Re: Starter for Old Merc..
Got to do some work today. I took the starter apart and cleaned and lubed it. When I put it in nothing, then I found a wire that goes to the small front post on the positive side of the solenoid which was corroded. Once I repaired the wire that starter engaged fine. Now here is the new problem. The starter cranks a few times and then nothing like it is a dead battery. I am guessing the battery is bad since I charged it before being put away in October but not since then and then yesterday when I charged it it took 9 hours.
Also on the lowerend unit do I use lower end oil or do I need to use the old grease that went in some of the earlier models?
