swamp-fox
- Joined
- Mar 10, 2011
- 103
I put back together my '78 90hp Merc. While I was trying to start it I noticed the wires were smoking from the wiring harness inside the motor. It seems the ground that goes to the cowl is getting the hottest. I checked the polarity on the battery and it was right. I had taken the harness out, when I did there was no rotten wires or touching. The only thing I changed was I used the yellow/red wires from the stator to the rectifier. There were heavier ones on there and the yellow/red were taped up in it.
If any thing it might not charge right, but not the ground get hot?
Also the starter is really really hot!! It's working perfect, but I don't think I grinded enough to where I can barley touch it....
Also I used crappy aftermarket carb kit, and they are stuck. No gas is going through the gas tube that goes over the top of the carb...
I think I will be ok after I change the carb kit..but I dont want to burn up anything..Any help will be greatly appriciated!!
