1981 60HP 2 Cylinder Johnson
I took my outboard out of winter storage. I am having a starter issue.
The starter gear fully engages the fly wheel but then stops. The starter motor and starter shaft are going like crazy but the gear doesn't move. Like it is slipping on the shaft rather than turning.
I took it apart and cleaned everything up and still it slips once engaged. The starter motor sounds strong and the shaft looks brand new. I looked inside the gear and it didn't look like it was damaged. But still the shaft spins like crazy and the gear stays still.
Do I only need a new starter gear or should I buy a complete replacement starter?
Any help or information would be greatly appreciated.
Also if I need either parts or a full starter where should I get it from? I need it in 2 weeks before I go on vaction.
Thanks in advance!!!!
