Hi,<br />trying to convert the above to electric start.<br /><br />Have "borrowed" parts from 25hp '76 Johnno - starter motor and bracket(had to modify slightly to fit), starter and choke solenoids, neutral switch.Motor already has points on it....<br /><br />Before I describe the symptoms/my faultfinding results etc, is this starter motor "big" enough to crank my 35hp?<br />it's got 2 brushes but my manual for the 35hp elec start shows 4 brushes - ?? a bigger starter motor needed for the 35hp??<br /><br />Here's the symptoms - turns over nicely, but sooo slowly.. like battery is flat.(it isn't...)<br />so voltages--<br />12.5v at terminals at rest.<br />10.7v " " on cranking.<br /><br />12.5v at starter solenoid input on cranking.<br />5v at starter input lug on cranking. (to eliminate solenoid, I direct connected battery to starter bypassing ALL wiring - same slowww response.<br />took flywheel off and cranked - starter spins beautifully (didn't do voltage measure - should I have???) - so it dies badly under load..<br />Given the symptom exists with original wiring or using short lenghts of new battery wire I guess rules out wiring anomalies.<br /><br />Which leaves me with starter motor failing under load. <br />???brushes??? not much else I can think of??<br /><br />Sorry about super long post - figure get you guys heaps info up front to help me if possible..<br />Thanks again,<br />David
