lunacyfringe129
- Joined
- Aug 10, 2005
- 8
I started the engine up the other day and took the cowling off to check things out and make sure they were all in order. After I shut the engine off after about 5 mins of idling in the driveway I noticed that my starter was still spinning ( but wasn't engaged to the flywheel). I shut off my battery and disconnected the starter so it wouldn't overheat, because I still needed to trim it back up to put it in the garage. It is still disconnected, but I don't know what would cause it to keep spinning even after the key is turned off.<br /><br />I would assume it is some sort of short in the wiring to the key, but im really not sure so I thought I should ask you guys.<br /><br />Engine is a 1989 Mercury Blackmax 150hp
