Starter motor
evinrude40HP
I have a 1971, 125hp evinrude motor. The stater motor turns on but does not engage the flywheel. The stater motor just spins. Can somebody please help. Thank you.
rickdb1boat
Re: Starter motor
Put some lube on the starter gear shaft. WD-40 will do.
DHPMARINE
Re: Starter motor
put your hand on the motor part of the starter,well away from the drive and flywheel.<br />Have some one crank the engine.If you don't feel the flex or surge,boost the battery,<br />still the same,rebuild the starter.<br />DHP
evinrude40HP
Re: Starter motor
Are there rebuild kits for such an old motor. The brand of the starter motor is a Prestolite. Also would there be a replacement for the starter motor.
DHPMARINE
Re: Starter motor
jorge22,<br />I do not know of rebuild kits,but someone in your area must rebuild starters and alternators for cars and trucks.These are the guys to talk to.<br />DHP
