I have a manual start 1976 Evinrude 25hp, that i want to upgrade to electric start. The flywheel is toothed, and i know what components i need to do the upgrade.
My friend bought a starter, bracket & solenoid he thinks and was told will work on my motor. I traced the part numbers 392133 (starter) & 331210 (bracket) and they came from a 1985-87 E/J 25hp.
Going stricly by the part numbers, obviously they don't match...i need 385401 (starter) & 317328 (bracket). What i can't find is what the actual difference is between the years, specifically on the starter motor. What i want to know is if the teeth on the starter motor will mesh with the teeth on my motors flywheel.
I know the bracket is slightly different by trying to dry fit it. I found that it will bolt up with small modifications. Bolt pattern is the same but there are small dimensional differences that would require some filing of the bracket for fitment/clearance.
Any help would be greatly appreciated!
DW
DW
