Starter Part Number Identification
ccave04
Hello,
I recently had my starter die on my boat and need to replace it. I do not have a local shop that I can have it rebuilt at so I plan on ordering a new one.
I have a year 2000 Mercruiser 5.0L V8. w/ a gen2 Alpha 1 Outdrive.
I have removed the old starter and their are no part numbers on it, just the contact information from the company that made, I am assuming it is an after market part. I am also going to contact that company and see if they could identify the part number or type of starter it is for ordering purposes, but I assume you folks will be must faster.
Basically I am looking for a part number / model number so that I can order a new starter.
I am attaching a bunch of pictures of the actual starter out of the boat, any information will be helpful. If I need to provide anymore details please let me know.
ccave04
Re: Starter Part Number Identification
Also, only thing that is stamped on the starter (at least on the outside I have not opened it up) is an A E.
The company who made this specefic starter is:
MES
One more picture:
ccave04
I have a SELOC manual # 3206 but I can't seem to find in there a starter model number or part number.
Thanks!
Bt Doctur
Thats the Hi-Torq starter for GM engines. Sierra 18-5913.Do you have an engine serial number?
ccave04
HI BT Doctur,
Thanks for the link, and the serial #. Before searching the part number you gave me I used your link to look up what I needed and came up with the same part number you provided.
Unfortunately I do not have an engine serial number. Should I go down to the boat and try to find it prior to ordering a new starter? Never looked for it, nor do I know where to begin.
Bt Doctur
check the valve cover, flame arrestor cover. usually a metal tag just above the starter
HI BT Doctur,
Ayuh,.... That's a standard marine staggered bolt pattern Chevy starter,.... like this one,....
