so i just installed a new pinion gear in the starter because the old one was so worn out that it wouldnt even turn the flywheel,and after starting the motor on muffs once this is what the new one looks like is this normal wear or are the teeth on the flywheel worn down also??
this is the old one
top view of new one installed
is there any way to get more tooth engagement...
this is the old one
