Starter / Power trim
I have a 1995 Merc 175 EFI on a '95 Lund. After the boat sits for 24 hours and I try to hit the starter it acts like it has low voltage(i.e. dead battery). but the battery is fully charged. If I hit the power trim up & down once, then try the starter, it cranks over fine. I have checked the battery connections and the connections to the starter and all seem fine. Any ideas out there?
Chucky P
Re: Starter / Power trim
Did you check all grounds. Even if it looks good try cleaning all grounds. hope this helps chuck
