Re: Starter Problem?
The starter motor, battery, cables & connections all need to be in good order for your starter to operate. Starter problems can be hard to diagnose. It doesn't take much to upset correct operation.<br /><br />There's a big difference in starter motor turning effort for a motor with and without spark plugs. So even a poor starting system will turn over a motor without plugs.<br /><br />I presume you have access to a voltmeter. If so, I suggest you start by measuring the voltage directly across the starter motor during cranking under load, i.e. between the starter motor +ve terminal and the case of the starter motor. If this is greater than about 9.5V suspect a starter motor problem (as JB says).<br /><br />If the voltage is less than 9.5V you are dropping volts somewhere else. Any resistance in the circuit will lead to voltage drop (and heat build up) and take power away from the starter motor. Check and clean all of the connections from the +ve battery terminal to the starter solenoid and from the solenoid to the starter motor. (As a clue, any bad connection should get warm when cranking).<br /><br />Check & clean also the -ve battery terminal & earth connections and also the earth connection from the starter motor to the engine.<br /><br />If this doesn't fix the problem, you may have a bad solenoid. If you have access to a voltage meter you can use the following tests to isolate the problem. Measuring from a good earth or preferably directly from the battery -ve terminal, work through the starting circuit and measure the voltage at each point in the circuit while cranking the motor under load: battery +, solenoid battery side, solenoid starter motor side, starter motor +ve terminal and starter motor case. The difference between these measurements will tell you where the volts are being dropped and hence where the high resistance is.<br /><br />Also make sure your battery is in good shape. The battery voltage shouldn't drop below about 10V when cranking.<br /><br />If the starter motor is turning over very slowly, the voltages will also go up and down slowly. Just take a consistent set of readings.<br /><br />Note that taking a voltage reading even if the starter motor is hardly turning will tell you how many volts are being fed to the motor. Say it's 10V at the starter motor and it's hardly turning, then you've probably got a problem with the starter motor<br /><br />Note that jumper cables can give variable results. It's easy to drop a few volts in a poor jumper cable connection.
