1980 Mercruiser 260 In A Bayliner Eagle. Have Motor Out To Correct Mount And Alignment Issues And Some Other Maintenance. I Discovered A Automotive Starter On It So I Replaced It With A New Marine One. New Starter Would Not Turn Engine Over Even Without The Spark Plugs In It. Shimmed Starter Out And Solved Problem. Put Spark Plugs In And Again Starter Barely Turns Then Clicks. Put Old Starter Back In And No Problems. Am I Still To Tight? Do I Need To Shim It Out Some More? By The Way The Battery Is Brand New 700 Cca. Both Starters Turn Engine No Problem With The Plugs Out But As Soon As I Put Them In New Starter Wont Turn It.
