Re: Starter Problem ?
I've had issues starting my boat since the day I got it (last month). Once warmed up, it restarts easily, but starting cold is another issue. Always sounded like it wasn't getting much fuel. I replaced the fuel squeeze bulb just to be safe, and pushing in on the key didn't seem to do anything. I read in my repair book that I could operate the enrichment valve manually, so I tried it and it starts much easier. The valve wouldn't click with the key switch, so today I took it apart and found the problem. The ground wire had come un-done, and once it was reattached, the Merc fires up easily when cold. Until this fix, the starter would turn and turn just like your issue. If it caught for just a nanosecond, I'd have to let off the key and try again. If its not firing up quickly, look at your enrichment circuit.
