I recently replaced the starter solenoid on V6 outboard. Started fine no problems. Today when I had it running and turned off the ignition switch the bendix was still rotating. I shut off power at the battery selector switch to shut it off. Now with the ignition switch off, when I turn the battery selector switch on the starter cranks the engine and the bendix stays engaged to the flywheel, it doesn't drop down like it should. Any help with this would be appreciated.
