Starter problem??
Clhart22
I have a 1995 force 40 hp outboard and ever since I bought my boat it's fired and started with no problem. But today was like any other I put in and rode up river then rode down river turning it on and off as I stopped and fished. But when I got to the boat landing I ran out of gas and the motor shut off I had some extra gas and poured just enough in to where I could load it up. When I went to crank the motor it acted like the battery was dead. But the volt meter was reading 12.8 and it's a brand new battery. I took the hood off and turned the key and the starter comes up fine but will only turn the flywheel one turn at a time really slow. Left it sitting for an hour came back and it started right up. Turned it off and tried to crank back up and the starter was lugging again. I don't know where to start any suggestion? All connection is seem fine and doesn't seem to be grounding anywhere
Pull plugs to make sure you havent ingested water
Clhart22
I checked and that's not the problem. When I try to turn it over the starter get really warm. Almost hot
ondarvr
Sounds like your battery may have issues, or there's a bad connection. Batteries can read can read good with no load.
mla2ofus
With a known good battery connect jumpers directly to the starter. If it still does it the shaft bushings in the starter need to be greased. My 90HP Force did that and I found the bushings were dry. 9 yrs later it still cranks it good.
Mike
Silvertip
Just because you measure 12.6 volts at the battery with no load means nothing. Measure the voltage when you have the key turned to START. Bet it drops like a rock. That points to bad cables or a battery that is not capable of "holding" a charge. Charge the battery and try again.
