oldpontoon
- Joined
- Jul 8, 2007
- 23
I?m new to boating and I apologize if I use the wrong terminology. Learning as I go here. I have a 1983 (I think), 90 HP Johnson outboard that has a starter that turns but the shaft does not always come up to hit the fly wheel and fire up. The motor is on a 26 ft JC pontoon so I tried to cover all my bases before I got this monster in the water (I need to have a friend haul to the ramp). I charged the battery and fired the boat up on dry land using a motor flusher. The motor fired up the first time. I stopped and started it five or six times with no problems.
I put it in the water, starts fine. Stop to swim and tried to start it again. The starter would spin at was looked to me a good speed but the shaft came up only a few more times to start enough make it home (I was having a time hooking up to the right tank so the boat choked on me a few times). I checked the battery poles and realized that the negative pole was loose and I tightened it. No change. I checked the connections to the solenoid and cleaned them manually (what can I used to give them a good cleaning) but they did not seem that dirty or corroded. Still no change. I tried to start is so much that I wiped the battery out so I need to recharge it. As I?m disconnecting it, I see that the wire that hooks up to the negative pole is frayed about 50%, could this cause the starter not to fire up fully?
I?m pretty handy and never done this but is it possible for me to learn how to repair the starter? If so can someone direct me to where I can see pics or videos? (if that is something that exist?) I know I can change the starter if I need to but would I save by having it restored, or doing it myself? If I need a starter, what data do I need to use to find the right part?
Thanks for any advise.
