Starter problems
phillie01
I have a 850 Thunderbolt,rewired,new gas componets ,had plugs pulled good pressure,new battery,water pump fine,need spray to start to avoid dtaining battery,once engine is warm starts fine 2,3,maybe 4 times ,then the starter doesnt engage,if i tap the bolt on top of the starter it engages,can anyone help me with this issue.
Chris1956
Re: Starter problems
First Cold start issue: Is the choke working? Make sure choke plates close when choke button is pushed. Set cold start lever all the way up and hold choke button while cranking until motor fires, when cold starting.
Starter issue: Starter could have bad winding, which gives a dead spot on commutator. Brushes could also be sticking. Need to open starter up, clean commutator and inspect brushes and springs.
