I have a bayliner w/ a 3.0 Mercruiser in it. Battery is at full charge when i attempt to crank i just get a click noise. I took a jumper wire put it on the postive wire and yellow ignition wire on the starter solenoid, i belive its called, which is on the top of the starter. Then i cranked the boat and it started. Does this mean i need to replace the starter? It is a GM style starter im not sure if i can buy just the starter or the solenoid by itself? Or am i even right on diagnosing the issue?
