manonfire296
- Joined
- Mar 23, 2009
- 12
I swapped out a 50 Merc for a 50 Force. Used a cross wiring reference chart to hook up the ignition switch and other wires. Now the engine will not start with the key. I took the starter relay off and tested it, and it clicked. I put it back on and placed DVOM leads to the different posts while turning on the key. I never got voltage from the red wire to the starter, the black to the ground or the yellow to the switch. All I got was batt volt from the batt supply. There was also no click in the relay during testing on the boat. Is the starter relay bad or is it a bad switch. The motor will start if I jump the batt supply terminal to the yellow switch post.
