starter selnoid connection help!!!
siego99344
i need help with the wirinf on my new starter.. the boat never came with a starter when I bought it. the starter I bought has an attached selnoid I believe the boat when it did have a starter had selnoids detached now ran into what wires go where and what is what... its a omc 351 v8 ford..
siego99344
No Title
siego99344
No Title
siego99344
got this new starter boat came with no starter to begin wuth but I connect the power to the large nut and the yellowish from the old solenoid to the small nut and well its already grounded so no ground and when I go to turn it on all I get is a click. I don't no what else to do.
siego99344
that's old solenoid and connected the yellowish cable to small nut still just clicks am lost
sam am I
Got ya, So leave the yellow wire as you have it and try this...........
sam am I
Serious? This site sure has hit the crapper!! Geeesh
sam am I
I assume you hooked the new starter up to the old main big wire without removing it off the old solenoid?
If so, you were trying to start through two solenoids in series(w the old one disconnected/not working).
So, to still re-use the old big starter wire on the new starter and bypass the old solenoid, just remove the big main starter wire's ring lug from the old solenoid's nearest to transom stud(as view in your pic here) and move it to the closest stud(as view in your pic here)placing it with and over the top of the existing batt. wire I've indicated in the call out note on your pic below.
When moved/done, both main big red wires(as seen here in the first pic) then will be bolted on this same stud together. They can live happily ever after bolted together there on that ole stud of you like and your trim/tilt solenoids, etc. will still continue to have their batt. feeds as well.
