Okay so I have a 97 evinrude 115. E115eleua, I just put another flywheel on since my last one was missing teeth. Put it on and still grinding like before. Shop told me bendix might be bent a little. Today it tried to turn over like usual, but then on the third crank it stopped, you heard it clicking but wasn't turning the flywheel, after a couple more turns of the key it cranked, turned over. And worked fine the rest of the day. Do I need a new starter or just the bendix shaft and pinion? I was told that if you buy the starter
Motor new it doesn't come with the shaft? Is that bs? I thought they came with the starter bendix
