Starter Slow Turning
legalfee
I've got a 1995 Force thats probably got the original starter. Recently the starter started turning slow. I thought the battery needed charging. I charged it. No Luck .I've bought another battery and charged it up. Same thing. Could my starter be bad? Any help greatly appreciated.
Start by cleaning every connection from the battery to the block and starter, including the starter mounting pad
catfishcarl99
im having the same issue. has been a slow starter for a decade. now I just went through and cleaned every connection. still very weak. attached a jumper cables to pos on starter and block. same. two different batteries one new. think mines toast.
legalfee
Got a new starter yesterday. I'll let you know how it works when I get a chance to put it in.
mla2ofus
Don't throw the old one away. Had a 90HP Force and the starter did that. Removed and disassembled it, cleaned everything and put a little grease on the front and rear bushings. Still worked fine 7 yrs later when I sold the boat.
Mike
catfishcarl99
heres what I just found. brushes toasted. brush holder broken. magnets in good shape. just got a new endcap with brush assembly for $34 on ebay. cheap enough. mine has been getting slower and slower. stopped today. surprised it started yesterday.
legalfee
I got a new one for around 150. I may take the old apart. Bet it looks the same or worse than yours.
legalfee
The old starter had a corroded, loose terminal. I replaced it anyway. New starter works like a champ.
