1998 Evinrude 40 hp E40TLECR Outboard Motor
Turned key and starter engaged for 2 seconds and then the Starter solenoid started arcing. When I remove the red power to the starter and turn key, solenoid clicks.
I had removed starer to get to shift rod connector, to drop lower unit.
To remove starter, I disconnected the ground on the battery, disconnected the red power, removed the 3 bolts holding the starter in place and lifted it out.
During reassembly, I attached the red power to the starter, returned starter in place, bolted it back in-place, reattached the ground on the battery.
Am I missing something? Or a bad solenoid?
